I installed some aftermarket lighting on my 2007 zx6r to the front of the zx6r now I'm thinking to hook it up to the nose light to avoid running it all the way back to the battery... Can I tap the positive wre on the nose light and run the negative/ground to the bolt behind the air intake which is basically the frame? I tried touching it and it worked just wanted I put if this will harm anything?
Thanks ps snow is melting here and keep the rubber side down!
