1 - 3 of 3 Posts
Hi Peeps,
My G2 won't turn over...
Battery has 12.36 volts
Cross the starter solinoid and it turns over.
Kick stand connector is wired across.
Push start button and it makes the fuel pump turn on!
It bump starts first time.
Any help? Thank you!
Hi Peeps,
12.36v static is super low.........
but you sure it isn't something simple like the contacts inside the starter button switch housing being dirty/corroded.....or go to the other end of those wires where they plug into the harness and unplug it there and clean those. Also are you sure the starter selenoid is actually good?!? ...... you are talking about a bike from the last century!
use some diagnostic skills and actually test some components!
Check fuses too
Specifically the starter solenoid fuse
1 - 3 of 3 Posts
