So i went for a long ride yesterday and then when i got home my key was stuck in the ignition, it turns perfectly but it just wont pull out. any ideas? i tried tapping the key with a hammer and that didnt work, and im about to go get some WD40 and try that
thats cool, you'll never lose it now......
But for real you can't grab it with a pair of needle nose pliers?
I always forget to pull out
Oh we've all been there but I'd be a bit more worried if it got stuck in! Maybe some lube is the way to go ;)
The the op, my key got stuck in the park position before and after about ahlf hour of wiggling it just suddenly went. Not quite the same as the key not coming out but just keep moving it about and trying until the pins properly align I guess
Turn and pull, keep doing and don't let off pressure, it will come out
yeah i shuda posted a model and year, but its a 2005 636, I tried WD40 now and it didnt work, im so ppissed off right now i cant go take the bike anywhere cuz the key will be in it!
Wd40, just did mine two days ago.
Put a rag under the ignition because it will leak out eventually. Squirt a good amout in on both sides of the key and let it sit for a couple minutes. Then when I got the key out I put a little more in.
