Keeping it clean, soft and supple
1 reading
3.2K views 20 replies 11 participants last post by  wiffy
#1 ·
For those of y'all that sport a set of leathers.
I got some questions for you.
This is not just for full suit, but all the leather you have to ride in.
One piece, two piece.
Sports jacket to double breasted spike stud jacket.
~What do you use to clean your leather?
~Do you condition your leather?
...what do you use?
~Are you sure you are using the right stuff?
Or...
"I dont use any of that stuff!
That cow/horse/kangaroo never used it when he had it on, so neither will I."
#3 ·
I tend not to ride in the rain much any more but if i do get caught out i just hang up the 2 bit suit and let it air dry in the house.. if its warmer out side they go out side and if in side is warmer then in side.. i dont use any thing soapy just wipe it down with a cloth.. you getting leathers mate?
#6 ·
Bug guts
#7 ·
My new 2-piece has just arrived and I'm going to put some conditioner on it before I use it. I figure that should be all I need for it -I'll do it every couple of months and hopefully it will keep the leather in good condition.
As for cleaning -I've always used warm water and a cloth. Never soap as I thought it could dry the leather out.
#8 ·
I read 2 excellent answers here....lanolin oil & saddle soap. I prefer the latter. Been using that stuff since I was a kid. Worked for my baseball gloves, a few pair of red wing boots, and two riding jackets. I've seen a suit that has been done with lanolin oil, and the results seemed to be on par with saddle soap. Don't know which was softer cause I'm not rubbing on another man. LOL...good leather shops like Wilson's have nice products also.
#14 ·
i never clean my leathers, are you suppose to?
to me a soft leather is gonna tear away faster against the pavement no?
#15 ·
That's gotta smell foul after about an hour or so. Lol
The abrasion and tear resistant properties of soft leather should be better than hard or rough leather. Take leather seats for example...if you treat them they remain soft and hold up quite nicely. However, if you don't, and let them get all hard they crack and tear.
I guess you hv to keep it moisturized. It is a form of skin after all, and skin does require moisturizing. Lol
That's just my theory on the matter.:O
#18 · (Edited)
OK
Here is my take on leather cleaning and conditioning...
I use saddle soap to clean and then I use mink oil to re-moisturize.
When you are cleaning, you are basically removing the oils from the leather along
with the dirt, so, it will need to do replaced.
There are tons of options to get this done.
Im just going to tell ya what I use and how I do it.
My son is still wearing a jacket Ive had from before high school.
(Ill try to find a pic.)
Any way...
The important thing is to not use alcohol or petroleum based stuff.
Think of it this way...
Leather is a skin, with fibers and pores, and they need proper lubrication just like
your skin. Because it no longer has a body to provide natural oils, we gotta provide
these oils or moisturizes for it.
A lot of products claiming to be "cleaners" and "conditioners or preservatives" are
not.
They contain harmful chemicals, petroleum, pine tar, or alcohol to clean, waterproof
or condition leather.
Ive heard, some people use a plain unscented moisturizer on leather stuff, but there
is moisturizers specifically designed for leather also.
Like I said, I use mink oil.
To use saddle soap, dampen a cloth, dip the cloth in the saddle soap, and work up a
lather.
Work the SOAP into a LATHER, ya know, bubbles, foam...
NOT into the LEATHER, into a lather.
Once you have a lather, rub the cloth with some lather on it in circular motions on
the leather. (not the soap itself, but the lather from the soap)
[you would be surprised at how many folks rub the soap onto the leather]
Allow the saddle soap foam to remain on the leather for just a few minutes.
Wipe off the soap using a damp washcloth. Be sure to wipe everything down good and
thoroughly so that no soap is left behind, it can cause the leather to dry out and
become cracked.
Even conditioned it will dry out because the soap is in the pores and not the oil.
In all fairness, there is statements like this...
"Many people swear by mink oil to condition and waterproof their motorcycle leather.
There are really two fundamentally different approaches to motorcycle leather care:
The way I describe it to customers is mink oil vs. a Lexol-type leather conditioner.
It's like putting Vaseline on your hands vs. Jergens lotion. Mink oil will clog the
pores of your leather, just as Vaseline creates a barrier between your skin and the
environment. That's why it will make your leather motorcycle accessories waterproof.
It will also eventually dry out your leather because the pores are clogged. You will
also notice your leather accessories may have a whitish haze to it. That's what
happens when mink oil solidifies in cold weather. To answer the question, it makes
more sense to put mink oil on your boots, if you so desire, and use a conditioner or
product like Chilhowee Buffalo Butter specifically designed for leather care and the
conditioning of quality Deer, Elk, Buffalo, and Cow hide."
In my opinion...
~"The way I describe it to customers..." you are a salesman or, you got sold a sales
pitch.
~If your leathers feel like Vaseline, you have put WAY too much mink oil on and did
not rub it in.
~My jacket is no longer alive to have natural oils filling in the pores, so its ok
for the mink oil to be there.
~I have yet to see any MAINTAINED leather product dry out using mink oil. Ever.
Unmaintained, yes, pores are clogged up with old, dried mink oil.
But Ill be maintaining my stuff because the pores need to be filled with something.
~If there becomes a whitish haze, once again, you have used too much mink oil or did
not rub it in enough.
Good luck and wear your gear...
Some gear.
Any gear.
ANYTHING.
#20 ·
Hi all,
I have spent a fair bit of time over the last few days searching the web for information about conditioning and looking after motorcycle jackets. A lot of it was quite contradictory, so I rode to a shop that does leather repairs/conditioning etc to see what was recommended. Surprisingly, I was told to DO NOTHING.
The owner of the shop said that motorcycle jackets are oiled at the factory and then painted over. He said that the conditioners that can be bought do not penetrate the paint, and while an oil/wax product can help with waterproofing a jacket, it will not increase the longevity.
He said that if the integrity of the paint is disrupted then traditional methods can be employed to look after the leather, but he said the best thing would be to take it to a store to have it repainted.
I was set on putting some sort of conditioner on my new leathers, but now I'm not so sure...
maybe something to keep the paint intact...
