Actually I was thinking of that seems safer for learning…thanks 👍Looks like it’s built right with quality parts. The only thing I’d change is that 12 bar and run a flat one. Clean bike tho 👍
It’s for sure safer to learn. Plus it’s a lot more fun dragging a flat bar lol. Can keep a titanium end for it like it’s got but just longer and flater. I’d imagine you could mod that pretty easy.Actually I was thinking of that seems safer for learning…thanks 👍
Really helpful information thank you. I will post my process when I make this adjustments !It’s for sure safer to learn. Plus it’s a lot more fun dragging a flat bar lol. Can keep a titanium end for it like it’s got but just longer and flater. I’d imagine you could mod that pretty easy.
if you are just learning you may want to run a bigger rear sprocket and when you are at the lot lower your tire pressure to 10ish pounds. Kills circle stuff that low but will feel more stable learning the 12oclock position and you can slowly add air and lower your sprocket size as you get comfortable
