1 - 9 of 9 Posts
Does anyone know if the jumper mod works if you have a slip on already. I spoke with someone at a shop and he said it will only work with the stock exhaust because the exhaust valve is still there. Anybody know for sure?:O
whats the jumper mod actualy do??
still trying to work out what it actually does but looking at the manual it earths out pin 50 on the ecu which is external communication line (mode switch) but thats as far as ive got
It works with and without the stock exhaust. Either way, it only take a couple minutes. JUST DO IT! Took you longer to get on the computer and ask then it would take to just do the mod.
arent you guys interested in what it does advance timing more fuel do you need to re map etc.
reason being i want to run nitrous so i cant have the timing to far advanced
so if anyone can find out what it actually does would be mint
update on this mod spoken to kawasaki and it plays around with fuel/air mixtures and the bikes timing should be good for 10hp will let you know once i get bike re dynoed
1 - 9 of 9 Posts
