did you sand or scuff up the frame before painting? and what kind of paint did you use?you don't need to remove the engine to paint the frame
take the tank and fairings off and use newspaper to wrap the engine etc .....then paint it
I done this and it looked bloody good for a few years till I stripped the bike down to the frame for a rebuild
when I first done the frame ....I flattened it down with some 1200 grade wet n dry and then painted it with satin pj1......it came out bloody welldid you sand or scuff up the frame before painting? and what kind of paint did you use?
thanks! im going to have to do that to my frame after this riding season.when I first done the frame ....I flattened it down with some 1200 grade wet n dry and then painted it with satin pj1......it came out bloody well
PJ1 Fast Black Satin Paint 400ml Spray s Engine Case 900F 500C | eBay
^This^you don't need to remove the engine to paint the frame
