1 - 15 of 15 Posts
It's the 'something I don't remember' overflow bottle. It catches oil if that helps anyone. It's supposed to be there, just tucked behind the fairings a little bit more.
you need to keep it clean ..but mine has a very small amount of black oil every now and then ...which the book says clean it out .. as for white i would get i tback to the dealers a.s.ap m8y..........
It is a catch tank connected to the air cleaner box to collect oil or water from the air cleaner...page 3-110 fuel system in the ZX-6R manual
The crankcase breather tube "breathes" into the top of the air box. The air coming out of this tube has oil mist in it. The oil eventually builds up and drains from the top of the airfilter housing into this tube/bottle. Its the small hole on the left of the airfilter from memory.
There should be another one from the battery breather tube, keeps the acid (and oil, fuel, and coolant) from doing all sorts of nasty things to your plastics...mmmm, all sorts of nasty things....
1 - 15 of 15 Posts
