I took the advice from kahearn and bought a hub from uhaul to integrate my turn signals. I have the turn signals working, but no brake lights which is kind of important. I have the trailer side hooked up to the two blue wires coming out of the back of the bulbs, and the green and yellow wires on the vehicle side of the harness are also connected to the blue wires coming from the white connector on the left hand side of the bike. The only thing I cannot figure out is which wire to hook up the brake switch to. The turn signals work, but aren't as bright as I had hoped, but I have no brake lights and those are kinda necessary.
Discussion Starter · #2 ·
Nobody can help me figure out which wire to tap into the get brake lights on an '02 zx6r?? I just need to know what color wire it is that I hook up the brakelight switch from the hub to.
use a test light.....that usually works every time to find out what wire it is...
sounds good, you should be able to find the wire fairly easily. Let us know how it works out for you.
