errr...not sure about the phsyics on that. longer levers means greater mechanical advantage. You'll apply greater pressure, but pull a greater distance. The reverse being true of shorties. I know some folks that like the shorties because they use a one finger pull, and its easier with them :OTo me it feels like you get more response for them. For example on the stock levers when you break, the farther out on the lever you pull the stronger the brakes right? You get more leverage, well these are short ,and a normal pull on the stock levers are about in the middle, on these they pull is on or near the end so you get the full leverage all the time everytime!
You're right, as long as you're pulling on the lever the same distance from the pivot.errr...not sure about the phsyics on that. longer levers means greater mechanical advantage. .........
I can fit my whole hand on my shorties but I have a puny hand. Although it took me a while to learn to shuffle my hand over a bit to get them all on. It hurt my pinkie for a few weeks before I got used to them but now it's all good and I cant imagine using the stocks ones!how many fingers can you fit on the clutch and how many fingers does it to pull the clutch in?
