1 - 4 of 4 Posts
ive just stuck a two brothers dual outlet on my 06 636. and its filth,
"however" the fuel injection light is on .
i also have a power commander ,but am a bit of a dur brain and havent worked out how to put it on!
does any one know ,if when the power commander is rigged up right, if this will solve the light thing. or do i need to do something else:
Anytime you mess with the valves on the stock exhaust that FI light will come on. So obviously when you put a new pipe on the light will shine...the new exhaust should've come with and piece to install to prevent the light from being on.
Yep, he's right, the kit should have came with the fixer, It goes on the butterfly valve under your seat, Then you have to clear the code. It's all explained in the file vault
1 - 4 of 4 Posts
