1 - 7 of 7 Posts
I got stuck in a flash flood the other day and now I have a check engine light. I’m trying to check the code but I can’t get it to pop up. I’ve tried turning the ignition on and holding the mode buttons but all that it does is flash the clock. Any other way to check without a scanner?
I believe u turn the key on, display the odometer. Then press and hold the top and bottom buttons until the code is displayed.
There's been discussion on here regarding the changes to how to read a code which came about on the '19+ model. If you search for it, I believe there is a dongle you need to have so that you can use a standard OBD II tool to read them.
Normally you cycle until the Mileage is showing in the Display then press both buttons at the exact same time, It may take a couple of attempts depending on how calibrated your fingers are ;)
1 - 7 of 7 Posts
