1 - 4 of 4 Posts
Hello people...new to the forum, first post! I installed some HID's on my 06 636 and the first time fired it up with one headlight in play..ran fine. Installed the second one and the bike tripped barely running...like a fuel management issue. Replaced back to the originals...ran fine after tripping the key 3 times. Next week, installed both HID's same time and fired it up...worked fine until now..back to the same! Any ideas?
Check the relay and voltage on the batt.
Thanks for the reply...will do...would that cause it to barely idle on start up any roll of the gas kill it
If that's the only mod you have done for the bike to be stalling, then you know that's it. Could be not enough juice in battery or charging system. Start with the obvious and go from there.
1 - 4 of 4 Posts
