Hi everyone I’m Nick this is Lilly the Green Goblin. She is a 2003 Kawasaki ninja 636
If the slack in the clutch lever cable is set correctly, you will more than likely need to inspect the clutch.I’m looking for some advise. This is the first Ninja I’ve owned and today after a chain and sprocket change, on the way back home, I started to get a slip in the clutch about 9k rpm, any ideas on how to stop this ?
Sorted. Thank you I had to loosen the clutch lever to allow some slack....thanks everyoneYup, check the clutch lever adjustment first. You need about 1/8" of free play.
