the fan itself is turned on based on what the coolant temperature is, not the engine temperature so every time it comes on it varies somewhat.
That being said mine USUALLY turns on around when my indicator reads around 200-205 if memory serves correct.
"When the coolant temperature goes up beyond 96 ∼ 100°C (205 ∼ 212°F), the radiator fan switch conducts to operate the radiator fan." -Straight from the Service Manual
After it is fully warmed up have you tried adjusting the idle screw to see if that helps? It may just need to be adjusted a bit after the engine is fully warmed up? That's my no spending money "quick fix" guess without tearing into stuff ha.
Edit: Sorry I re read that and it did kinda come off as rude haha. Most people think that its the temperature of the "Engine" like the block that the indicator shows..I said that just for extra emphasis I guess lol.
Here is the service manual for the J series Kawasaki if you don't already have it, provided by EvilTwin here on the forums
http://support.bazzaz.net/service_manuals/ZX600J8F.pdf
You could look into some good information with it.
