Hey,I need some advice on possible problems linked to a problem with my bike,I could only go 100km/h when the bike wouldn't go any faster,in 1 and 2 gears I could but the bike would shake back and forth like it was starving for fuel in 3,4,5,6th it reaches 100km/h perfectly and then nothing,I twist the throttle nothing,it remains on that speed,with a head on wind it would lower the speed to 80km/h..the administrator asked me to try to remove the tubes,I was reluctant to do this,I scratched my head thinking ignition system,maybe plugs,until today I took the tubes off the airbox and took it for a spin,,yeah yeah problem fixed she runs up to 160km/h no problems..I'm guessing the flat sided carbs maybe jamming closed due to wear and air pressure...do I need some new carbies?? has any of you guys had this happen and have they found the solution..thanks Rayz
ps there is some carbs off a 2002 model are they the same as the 1996 model
