Gringing noise
1.7K views 6 replies 3 participants last post by  Jcarr
#1 ·
I have an 09 zx6 and a couple weeks ago I noticed a slight rattle that sounded a lot like a bad throw out bearing in a car but this didn’t change when the clutch was engaged. It done it at lower rpm’s mainly. Then couple days ago I was leaving work and luckily before I pulled out on the road it sounded like something came apart and sounded like a marble was bounce around and it tried to lock back wheel down. Now when I try to start it it’s got a load high pitch grinding sound. A changed starter and looked at the clutch. Does anyone have any idea to what this can be?
#6 ·
If you're not seeing it in the oil yet, you may have gotten luck and still have an engine that could be rebuilt. There's no telling what has happened; the odds of it being serious are very, very high. If you dropped a valve and that scored a cylinder you would hear some nasty sounds. It might be external to the engine/transmission.... the transmission output shaft bearing my have gone, or something similar.
Put it up on a stand and in neutral spin the rear wheel. Do you hear the noises you are concerned about? Does the wheel spin normally?
#4 ·
