So I've got a 95 ZX6R. I got it after been sitting for about 4 or 5 years so the tank was Rusty and carbs were gummed up. Carbs cleaned up pretty easy but I was having issues getting the tank clean. So I used muriatic acid.
I thought I had the tank clean before I hooked it back up but evidently not. So I got some erratic acid inside the car bowls and the carburetors and it is causing havoc
The bowls are almost filling up with oxidation stopping the floats, the carb necks are getting it to stopping the throttle plate from opening.
I've tried everything I can think of to stop it. I've used carb cleaner, I scrubbed them, baking soda, I soaked them in a cabr cleaning solution that's in a paint can. Seems like the little bit that got in there would wear out eventually but it doesn't seem like it has really worn down at all maybe a little bit but not much
I'm at my Wit's End and I have no idea what else to do! Anyone have some advise or even a guess about something i can try? Thanks in advance!
Ill post pictures soon
