1 - 2 of 2 Posts
:O hi I'm new here and just looking for some help on my project i just got ninja engine is there anyone who can check the engine code to tell me what cc it is 599 or 636. and also best place to get parts used i think i need loom and edu also one carb
Hello and welcome!
As far as the CC's on the engine:
...the correct code. It should look something like this - zx600ae041024
So basically if it is a 636 it will say zx636xxxxxxxx If it is a 600 it will say zx600xxxxxxxx.
the front of the motor, left side should also say, 599cc or 636cc, cast into the block.
It's an 05/06 engine. You can tell by the clutch cover, and the speedo sensor on the top/back side of the case on the output shaft side. The cyclnders will have 599 or 636 cast into them to ID which engine size it is.
05/06 636cc engine more than likely.
1 - 2 of 2 Posts
