1 - 2 of 2 Posts
After swapping my transmission the gear no longer shows on my cluster. Also, it was giving me a problem before swapping transmission it would lag and display the gear a little later than it should. Do you guys think it’s a sensor problem or internal trans problem?
I need help!
Pull it out and make sure the plunger arm is there and the spring and clean all the contacts
1 - 2 of 2 Posts
