1 - 3 of 3 Posts
So I swapped out my brake lines with some new ss ones and when trying to bleed them I was having a hell of a time so I went and rented a brake bleeder kit that you can pull a vacuum with.
So the front 2 calipers bled fine and I went to do the master one last time and go around again just to make sure, but when I pulled a vacuum on the valve I could hear air being sucked in, so I felt around and noticed that it was seeping in right around the bleeder.......
I ordered a master rebuild kit because it needed anyway since it's an 05 and has never been done but is there something I can do in the mean time to fix the air leak?
Is finally nice around here and I want to get out
As long as the bleeder nipple on the mc is not leaking it's fine. I think u might be talking about the sound of air beinng sucked by the vacuum around the nipple since It's not a tight seal
With the bleeder closed I hear the air, it doesn't happen on the bleeders on the calipers.
1 - 3 of 3 Posts
