Hi. Today I had my first encounter with brakes. It was just on my kx250f so I wasn't worried about giving it a go with no previous experience whatsoever. Long story short, I whipped off the pads and got the new ones in with no problems but on the test ride the brake barely worked at all. I don't really see how air got in the lines but i cracked on with bleeding. I bought this little one way valve ages ago in preparation of this day arriving so thought id give it a go. I slapped it on the nipple, undone it and then started pumping and as soon as the reservoir got low I topped it up. By the end I had a constant stream of fluid going in and was pumping the pedal at the right speed to stop it overflowing. A few mins later i closed the nipple, tested the pedal and had a rock solid footbrake with no drama whatsoever. Have I discovered some very simple but super effective way of bleeding brakes or is there something very different when bleeding brakes on the zx?
Thanks
Here's the valve
Thanks
Here's the valve
