Hey -
first & foremost, I'd like to introduce myself as a noob, a noob who has just as much crashing experience as he does riding exp... :drool
anywho... i'm lookin for help troubleshootin my problems...:dowhat
I removed the front fairings on my zx6r because they were practically falling off when I bought the bike. this means that the stock air intake system is not being used, however the ducts that pass the air through the frame remain in use.
The cross sectional area of the ducts and original intake mouth appear to be about the same, so I never 'foresaw' any issues with removing the front air-intake structure. The other part that is not hooked up as it was is an air hose that was connected to two (one on each side) pipes that stuck forward within the intake manifold that had ~1cm diameter. The hose goes to a device that appears to be some kind of a pump, I'm guessing some sort of pressure generator for fuel system or something... but what I dont understand is how not having-it-installed with the little plastic pipes (with same diameter) can cause an issue.
I cant actually say that this is the culprit of my issue, but I might as well explain the issue- at around ~6k rpm the bike acts unstable, like it's about to stall... the tone of the exhaust changes dramatically, and the bike starts doing the harlem shake, all of this starting in an instant, it doesnt seem to come slowly, it just goes from riding beautifully smooth to shaking and sounding like a giant weedwhacker...
unfortunately, after my last crash i broke my coolant reservoir and frameslider and dont have the dough at the moment because of the expensive helmet I bought. so I'm not very smart trying to figure out which one of the things wrong with the bike, caused the 6k-stutter without being able to ride the bike, but I'm just asking you guys here if you might have experience with air intake based issues... or fuel issues brought on by intake mods...
any info or suggestions greatly appreciated-
thanks
-pat
thanks
-pat
