I need some help guys after my bike was in storage this winter I was getting a code 62 so I bought a used set of throttle bodies off ebay the were tested and guaranteed to work I put them in today and I'm still getting the same code what could this be?
Did you check the voltage of the wiring and the throttle position sensor? code 62 covers all of that. There can be a fault somewhere else in the system. Code 62 just doesn't mean your throttle bodies are shot. In fact, its most likely electrical.
Ok thanks what could it be electrically besides the ECU? I'll have to run some tests tomoro
Any wires involved with the throttle bodies. Check the service manual. It'll give you a better idea and will tell you what the thresholds should be.
