Let me preface this by saying, i am not overly inclined, mechanically so this may sound like a dumb question but here goes.. if i have an exhaust leak back closer to the end of the exhaust system, specifically by the muffler/pre-muffler, how bad is it? for context, on my 2014 zx6r i recently replaced the stock muffler with an aftermarket slip on. after getting everything installed i noticed the most minimal (and i mean MINIMAL, i dk that i can overstate this lol) pinhole exhaust leak where the new mid pipe slips into the pre-muffler section of the exhaust. the exact location of the leak seems to be on the pre-muffler, RIGHT below the clamp that holds the mid-pipe in place, in one of the pre exhisting slits in the pre-muffler. given the fact that it was so faint that i had to hold paper over it to even confirm that what i felt with my hand, was an exhaust leak, how important/necessary is it to fix/seal this? i don't know if this is a "if it doesnt bother you it doesnt matter"..or a "if you dont fix it something bad will happen or get worse". the most common theme seems to that an exhaust leak could equate to a loss of power(among other things). if there is, i don't notice it and i guess i'm just wondering if it's far enough back in the exhaust system that it truly wouldn't even matter/make a difference. it's a 2014 but i got it with next to no mileage on it at the start of this year. there's barely 2k on the gauge so as far as i'm concerned it's a new bike and i want to keep things in good working order, but if this is more of a preference thing over a necessity thing, i don't feel the need to fix it. Thanks in advance for the input!
You wont likely have lost any power with a very small leak. Other than a more annoying exhaust note, it's nothing that will cause damage. Try and see if you can't clamp it down better or something.
Most exhaust have an intentional very small hole in the metal at the lowest point. That's to let the condensate drip out. Burning fuel creates a small amount of water....some the hydrogen in the hydrocarbons chemically bonds with some of that oxygen during combustion, and when you pass warm exhaust over a cold muffler, it tends to precipitate out.
What RJ said. It is intentional to prohibit water to accumulate in the exhaust.
Sent from my ELE-L29 using Tapatalk
Yup. Also, with the upward tilted muffler, rain will get in there if/when the bike is parked outside during a downpour. So the hole also lets that all drain out.
Discussion Starter · #8 ·
Thanks for the input all. I'll start double checking that everything is as tight as it should be and go from there. I was kinda thinking it was intentional too, and then i though that the top side at like 45 degrees would be an odd spot for an intentional hole lol, so i came here for some opinions. After some more research and the feedback from you all, I'm thinkin i may just use a tiny bit of sealant if need be and call it a day(if i even do anything at all)
