Can't hurt to ensure the exhaust system is leak free.... Do you know if the flash had features to work with an auto blipper, etc.?
I worked on it for a bit today. The exhaust is good, no leaks. No the flash doesn't have any features like that, and in fact I talked to the guy today and he said he didn't even change anything pertaining to the idle.
Did you reflash it? I had it flashed before with Schnitz. They use woolich software. Sounds like something is off with the fuel map.
Yeah I did since I'm using a different exhaust. The guy that flashed it also uses Woolich and he's been racing ZX6R's since the early 2000s. He has flashed many '13-'18 zx6r's including his own, with the exact same mods as mine. I got my exhaust from him, exactly what he runs on his bikes, so he already had a flash ready to go for this setup.
I turned the idle up a bit and that helped it out a bunch. I couldn't get it to stall anymore when blipping the throttle. But it shouldn't do that even at the stock idle so I'm not sure what's going on. I'm pretty sure there's no issue with air intake, as I had already checked the filter, air box, velocity stacks, TB's before. There's no air obstruction of any sort, so it's gotta be fuel related. I'm wondering if the fuel filter might be a big clogged, or something with the injectors, just because the bike has been sitting for quite a bit. This bike hasn't been ridden for quite a few months, right? When's the last time you rode it? Around August?
The only error code I get is 39, which is due to the battery thing that you told me about, and I've looked into that more. It wouldn't have anything to do with this problem.
