1 - 9 of 9 Posts
Ok guys I was going to post in here http://www.ninja6zone.com/forums/showthread.php?t=1354
But I didnt want to go off topic and hijack the thread.
But my question is:
I have a 07 ZX-6R i want to do HID in both lights, now do I need to do this relay mod to my headlights for both of my HID lights to be on?
So what I am asking is if I just install the HID, will just one light come up and when I hit the Hi-beam the other will turn on?
Thanks guys for the help =)
I'm not exactly sure how it works, but I know that the new bikes are designed to run with only one light on when using the low beams and an article I read in cycle world or something said that when you change your lighting system on any of the new bikes that it doesn't help anything, actually it makes it worse because the lights aren't shining where they should be anymore and their blinding other drivers on the road. I just run with high beams on all the time unless I'm directly behind someone at night.
Buy a kit from here..... http://stores.ebay.com/pipi-stuff168 I boughta kit from here and its been working perfectly for 10 months. They have all the different bulb sizes and colors available. $130 shipped
If you hook them up just like the regular halogen bulbs(easy to install, all plug and play), then low beam is 1 HID and high beam is 2 HIDs. Just like the stock setup.
Any idea what Bulb my 07 takes?
Ok found out they use H11 or H9 for the 07's, damn I still wanna run both at the same time =(
Ok, so just leave the switch on Hi-beams all the time. I have both on during the day. They work the same as the regular bulbs, 1 HID low beam, 2 HIDs high beam.
1 - 9 of 9 Posts
