1 - 7 of 7 Posts
In the next few months Im making the change over to -1/+2 sprockets, and I am trying to figure out which brand I should go with. I would be getting steel sprockets not aluminum....I don't think the few extra ounces of weight loss is worth the extra wear. What brand sprockets are you guys running that you recommend.
I've used both and vortex has been the only sprocket that I've had teeth break on. Just my experience, I run driven on all my bikes now. Never had problem and get them in the chain kit for less than $200
Reactions: Dale W2
Sr. Penis Inspector
Supersprox Stealth. Aluminum inner, steel outer teeth. Best of both.
I have had steel vortex sprockets on the front and back for a couple thousand miles now. They are holding up great and no noticeable wear.
1 - 7 of 7 Posts
