Got my Dr. X Extreme Tailight installed yesterday. It's so awesome it's almost squidly. There is some serious poser value to this thing. Unfortunately my Scorpion Hi Mount ate the ability to mount normal blinkers on my rear so it was an intergrated or coming up with a solution (Read: Thinking). So naturally, I went with the intergrated. First things first, this thing is BRIGHT. I mean, you are seeing about 12 LED's in your vision for 20 minutes if you look at the thing. The blue LED's in the corner are ghey, very bright but look kinda nice. You can switch them off my just hitting the brake 3 times. Nifty. My programming thing doesnt seem to work though (Cos it's second hand probably) so I have to manually turn them off everytime I start her up. It does all other sorts of crazy shit I'll never use, too.
Installation was easy as but now I have a problem. I also got the Dr. X flasher relay cos it was pretty cheap and I am lazy. Now, when I turn the blinkers on the rear are going slower than the front so after a few blinks they are completely out of sync. Before the flasher relay I had hyper front blinkers and normal rears. Why is this? I'm a bit worried about the negative thingie because I have both the PCIII and the Tailight piggybacking each other on the ground terminal of my battery. Is this why? Someone help me out please, I asked the same question on Kawiforums and all I got was tumbleweeds.
