An extreme example of this was the attempt by the Navy to recover and recondition components of an
F-14 Tomcat that had left a runway at (then) NAS Alameda, and ended up in SF Bay, in '87 or '88.
I don't know how long the aircraft was submerged; my guess would be less than 72 hours. The article I found says it was in 12 feet of brackish water.
I worked with the guy in the corrosion control lab at (then) NAS Miramar to try and recover circuit boards, and black boxes so that they could be re-used in other aircraft.
Military aircraft circuit cards are all built to a much higher level of environmental protection, than anything sold to civilians. Rugged enough to survive 9 G turns, severe levels of shock and vibration, everything on the board is conformally coated in a lacquer or other material clear coat so that they are far more resistant to the effects of moisture and dust than typical commercial off the shelf electronics.
Dunked for a few days, then however long it took to get the parts to San Diego, and we started in trying to remove the salt and repair the circuit cards.
We did everything we could, from ultrasonic cleaners, to chemical conversion processes, to extreme drying, lots of solvents that would make a safety representative run away.... no matter how well we flushed, rinsed, washed, scrubbed.... there was always residual salt that could not be removed. The boards would look frosted within a day or two after every treatment we tried.100% loss.
Commercially produced high volume electronics are most definitely not built to that same standard, unless they have a specific requirement to do so. The ECU is an example of one approach to making electronics robust in the face of weather. Everything inside the enclosure is flooded with some sort of inert non conductive filler -- in the military that was called 'potting', and was done with everything from silicone RTV, to epoxy. Dumping heat is always an issue when you do that.... hence why the '05 ECU fries. Somebody cut the margin too thin.
The weak link is always the interconnections.
I quote
Sir Stanley Hooker frequently when talking with engineers.. "The greatest impediment to progress, is the interface between disciplines." (He was knighted by the Queen of England, for saving Rolls Royce from going bankrupt as they tried to build the jet engines for the 747. Bragging rights between development teams nearly did that in.)
Any time there is a quick disconnect on a wiring harness, or a plug and receptacle, there is a change in the amount of contact. In order to make it so you can mate the male and female pins, you have to have mechanical clearance..... air gaps stop the (easy) flow of electricity. Switches, and connectors all use a very limited number of points of contact to make the connections that are needed. In the case of a connector, the male pin has a dimple on it that is left with a sharp edge. As it is slid into the female pin, it scratches away any preservative on the mating surface (or corrosion) and that allows a low resistance connection. Bare metal exposed to a damp environment..... corrosion inevitably occurs. It's simply a matter of how long it takes to corrode enough to cause a problem.
always a good idea to disconnect the plugs on your wiring harness.... that scrapes off the corrosion, and puts the contacts back into direct connection on bare metal instead of oxidization. This is where the dielectric grease comes in. The contacts can push through it, but it flows around that point of connection and seals out air and water.
The kill switch is another example. If it is never moved, it will eventually fail because the dissimilar metals in the contacts will corrode and create a high resistance path. Same thing with the side stand and clutch switches. So long as they are used on a fairly regular basis, the 'make-break' will scrape away the corrosion. Add in dirt and water......
Relays, same thing..... the wiper from the common pin to the position it constantly sits on will eventually rust to the NC pin, or the rust will never let it make contact.
