I installed a fender eliminator kit on my 2012 ZX6R from Targa. I wired everything correctly according to the schematics. Everything works fine, except my left blinker is very, very, VERY dim and hardly flashes. My right blinker works fine. I hear the relay etc when it clicks on. During troubleshooting I found that the left LED is fine. I swapped the adapters around and swapped the wires around and found that the left light worked while the right one didn't. How can I make both lights normal? Seems like only one can be normal while the other is super dim. I've read through several topics on here and read about resistors and relays. Would a relay fix the issue, or would I need resistors in this case? Pictures should be attached to the post.
