1 - 7 of 7 Posts
The bike is an 07 zx6r. Bike has run last season beautifully. Sat for about 8 months with fuel in it. I emptied out the gas and filled it with new gas. Fuel pump wasn't building pressure and was clearly shot so I replaced that along with a new fuel filter. When I go to fire it up, it cranks great but then just takes a bit of effort for it to fire up. When it's started, it idles poorly and will stall if I don't give it throttle to stay at above 2k RPM. As the title states, the throttle is very delayed (about half to a full second delay). The bike won't rev past around 6-7k RPM, but if I want it revving that high, I have to ease the bike there and if there are any sudden throttle changes and it won't rev past 4k.
Anyone have any ideas?
Are your injectors spraying normally?
Is your intake clean?
Spark plugs good?
Make sure your butterfly valve in the exhaust isnt stuck closed (if u still have original muffler)
I'll try checking the injectors and take them to a shop to professionally clean if they're clogged
Intake is clean
The plugs have been replaced right before storage (8 months ago). Could they go bad just from sitting?
I have an aftermarket exhaust
Have you done valve maintenance recently? Had very similar issues when my camshafts were off.
Could also be worth checking vacuum lines.
As far as I know, there was a valve adjustment on the bike shortly before I got it. Only put about 50 miles on it since I got it (7050 miles total). Ran fine months ago before storage.
Just checked the vacuum lines and there seems to be no leaks.
1 - 7 of 7 Posts
