1 - 4 of 4 Posts
Just a quick question is it normal for the bike not to start with the clutch pulled in, just sounds like a flat battery, just start without touching the clutch stars no bother 🤷‍♂️. Was at it yesterday for ages before I discovered this 🤣🤣🤦‍♂️
No it's not, Sounds like an issue with the Safety Lockout with the Clutch Switch either missing and wired out wrong or still there but wired out wrong.
Has the side stand Switch been removed ?
Do you see the Neutral light come on when the Bikes in Neutral ?
The bike has possibly been not used properly for a while, I was showing someone tonight and it worked with the clutch in 🤷‍♂️ typical 😁, so 🤞 it's sorted itself, I'll just keep any eye on it cheers 👍.
The clutch safety switch up on the clutch perch is a common failure point and yes they can get intermittant before full failure.
it is just some spring brass contacts and they get dirty and corroded, it does pay to clean and lube them, or you can simply bypass it all together and get rid of the nanny features
Reactions: Tamzed1
1 - 4 of 4 Posts
