1 - 10 of 10 Posts
Hi peeps my clutch lever has started rattling through 9k-10k rpm.
Anyone know how to get rid of this pain in my anus?
Also can anyone reccommend some sticky summer tyres? On bridgestone BT014 at the mo, leaving black marks is good fun but sometimes scary :)
Sounds as if the bushing in the lever is worn out. You should be able to replace it. As far as tyres go,I prefer bridgestone's and if the the 014's are'nt doing the job you want....try the new 002's,they'll get it done.:thumbup
Michelin Pilot Power's all the way! Just put them on my 01 ZX-6R and love em....
Being a 2005 (going by the profile) I doubt the lever bushing has worn out. More likely you need to adjust the clutch cable/lever pull. There should only be 2-3mm play before you feel tension on the lever when you pull it in.
My '07 zx6r clutch lever rattles some at the same place - adjusting and tightening the lever helped some, but not completely. I'm putting on Pazzo levers this weekend anyway, so I'll have to report if they clear it up completely.
thanks for the replies. Tried adjusting it no joy. Might try the new michelin dual compound tyres. Anyone tried them yet?
Mine was loose too (06). There is a small 10mm nut on the bottom. Tightened it up a little and problem was solved.
i think we're gonna need to see some more pictures of your '07 when you get those pazzo's :devious
-:banana
Hopefully tonight!! They shipped Wed.... Pictures for sure!!
BTW: Same fix here on my clutch - just tightened the nut and got rid of most (but not all) of the buzz... Just got used to the remaining "fizz"... ;-)
-:banana
1 - 10 of 10 Posts
