Hello all, this is my first post and my name is brad. I bought a 2003 zx6r about 3 months ago. I got it home and parked it right away to start maintance on the bike. Put 08 rotors, 08 rear shock, new brakes, new chain and sprockets, new coolant, new brake fluid, and new fork oil in the bike so I felt safe. Plus the previous owner warped the front rotors running steel on steel. Anyways the bike sat up until a week ago and out on the first ride I felt some clutch slip at higher Rpms or when dumping the clutch. So I get home and tighten up the cable a tad bit and go to get back on, bike will not move. Just simply revs out. So I let all the way out and adjust my lever to 1 and get clutch back but still slips under extreme conditions. Guy said he had just changed the oil and it looked really fresh so my though is wrong kind of oil. I'm thinking the friction plated have swelled and that they are probably toast. So I changed the oil just to see if it would help and nada! Btw shell rotella t6, I live and die by this oil!
What's everybody else's opinion on this?
