1 - 20 of 41 Posts
I wrote this for another forum some time ago. Since we seemed to have a lot of suspension questions lately I thought it would be a good idea to repost it here. Understand that this is my understanding of all of these concepts and that you should do your own research.
This all started in a discussion where I stated that I only use the front brake on a sportbike except in very rare circumstances; Usually when I am going off-track. I also stated that there is a very advanced technique (more advanced than I am capable of using) where truly pro-level riders will use the rear brake to counteract aggressive trail numbers. The following is the massive detail that I had to go into to provide a framework of understanding.
The explanation
Man this is going to be involved; I am going to have to make diagrams and all that. Plus I am going to have to go very very deep into chassis geometry theory for people to understand why using the rear brake on the racetrack can actually be a good thing in very specific circumstances. Having a workable understanding of basic physics would also be a big help here.
I am going to preface this once again with a warning that this is a very advanced technique and not something that anyone should bother using unless they are at the absolute top of their game. Used improperly this will cause you to crash. Disregard my warning at your own risk. If you do decide to try this anyway, remember that I need a set of wheels for an '09 600 when you are parting out your bike :p
Whew, I have to think of where I want to begin. I suppose we should start with some terminology. It is important to understanding this topic that the reader comprehends rake, trail, swingarm angle, ride height, wheelbase, and the gyroscopic effect as well as the effects each of these things has individually and in combination on how a motorcycle handles.
Understand that this will be a very condensed overview and will be by no means comprehensive. People write entire books devoted to this subject. Tuners devote their entire lives to learning the subtle nuances of chassis geometry. It truly is a mix of science and black magic. Ever listen to a MotoGP post-race interview? Often the rider will say something like "We were really able to turn some good laps once we got the suspension sorted out." This is everything in racing. Raising or lowering the front forks 5 millimeters is the difference between a bike that works, and one that doesn't. That is roughly half the thickness of your average smartphone.
It is also important to note that everything is a tradeoff. Changing any one of the characteristics I mentioned above will have a positive and a negative effect. The magic of suspension tuning is to find the exact right combination where you get the most positive effects while minimizing the negative ones. Hopefully this will give you some idea of the scope of just how massive and challenging this is. There are so many variables and I will not even be going into things like compression and rebound damping, spring rates, preload, etc.
RAKE
Rake is the angle of the steering head relative to a perpendicular line drawn from the ground. This is a fixed number since your steering head is a welded component of your frame. Most sportbikes sit around 23 degrees of rake. By comparison, most cruisers have around 26 degrees of rake.
Less rake makes the bike less stable, but turn in quicker. More rake makes the bike more stable, but turn in slower.
A little makes a lot of difference here. Remember this is in a 360 degree arc. Those 3 degrees is the difference between turning like a Harley and turning like a GSXR.
TRAIL
Use the above diagram as a reference. Draw an imaginary line straight down from your front axle to the ground, mark that spot. Next draw an imaginary line straight down your headstock. Continue that same line all the way down to the ground and mark that spot. Trail is defined as the measurements between those two points.
The effects of trail are perhaps the most important part of setting up a working chassis geometry. Like everything else, trail is a tradeoff. Less trail makes the bike less stable in a straight line but makes it turn in easier/quicker. More trail has the opposite effect, making the bike very stable but hard to turn.
Think of a shopping cart wheel. They are offset. Why is this? Because when you push the cart, the trail of that wheel forces it to go in the direction you want to go. If there were zero trail, the wheel could very easily turn sideways while you want to go forward!
The general rule of thumb here is to have the least amount of trail (so you can turn quick) while having enough trail to keep the bike stable in a straight line.
Have you ever experienced headshake? Where the front end bars move quickly from side to side? This is a result of a low trail number. This isnt always a bad thing though.
Things like steering dampers help us to have even more aggressive trail numbers, to the point where we would get headshake in a straight line but the damper keeps that in check. We are "cheating" the physics of chassis geometry in a manner of speaking.
Rake and Trail work together to determine a large part of how your bike turns. The goal is to find a balance that works between the two but generally speaking rake is set from the factory as they built the frame. Trail is what we have to work with.
SWINGARM ANGLE
Refer to the picture above. Swingarm Angle is the angle between a horizontal plane through the front swingarm pivot point and where the rear axle is. This setting has a direct correlation to how well the bike "hooks up" or gets traction.
We need to tune the swingarm angle to counter "squat", or the weight transfer to the rear of the bike as we get on the gas. Some weight transfer is good and it helps to improve our traction but too much can cause the bike to run very wide under power or worse, loft the front wheel while at lean. This makes for some great photography but sucks when it comes to actually turning the bike.
The main force we are considering here is thrust, the force of the wheel pushing the bike forward (and up). The up part is what counters the squat so we call this "anti-squat". Because the swingarm is below plane, the thrust actually pushes the bike up. Picture a ladder propped up against a house. If you push on the bottom of the ladder (thrust it forward) the top of the ladder goes higher on the house, right? Now, if that ladder were flat on the ground and up against the house, no amount of thrust is going to get that to move up. This is why it is important that we maintain a swingarm angle below the plane of the pivot.
The big trick and tradeoff is to find the right amount of angle that counters just the right amount of squat so that you maintain a stable and easy geometry when accelerating out of a turn.
Sportrider.com did a fantastic writeup of swingarm angle. Read it here: More Fun With Geometry | Sport Rider
RIDE HEIGHT
We call it ride height, but really the purpose that it serves (other than making sure you arent dragging parts on the ground ) is to counter squat. The goal would be to remove as much squat as possible from the ride while still maintaining handling characteristics. Remember where I said everything is a tradeoff? (at least 10 times?). Guess what? This is one too :p
Raising the ride height counters squat BUT it also increases your swingarm angle and raises your center of gravity. A well-sorted motorcycle will have enough ride height to obtain the optimal rear swingarm angle while providing adequate ground clearance while having the lowest possible center of gravity. Not so easy, eh? There is a reason why racers pay BIG dollars to their tuners. The few people in the world who really understand this (I am not one of them) earn more money than the president of any country. The reason Valentino Rossi could go as fast as he did (up until this year) was Jeremy Burgess...his tuner.
WHEELBASE
This is the measurement between the front and rear axle. It is measured when the bike is at rest and without any weight on it. What a lot of people dont understand is that this is NOT a static measurement, it changes depending on what you are doing on the bike. Understanding this is a key component in learning how to maximize a motorcycles handling potential.
A shorter wheelbase has the effect of making the bike easier to transition (quickly going from leaned over in one direction to the other) at the cost of some mid-corner stability. Longer wheelbase the opposite. Harder to transition/turn but more stable. Also your wheelbase has an effect on your ability to keep the front wheel down under acceleration. Drag bikes stretch their swingarms to make it harder for the bike to wheelie while our comparatively short wheelbase ZX6Rs love to loft that front wheel in the air.
Since the swingarm is on a pivot (where the swingarm attaches to the frame) and that swingarm is on an angle, it can alter the wheelbase of the bike as the swingarm travels up and down in its range of motion. I made some pictures to help illustrate this.
This picture is with zero degrees of swingarm angle. That is; the axle for the rear wheel and the pivot where the swingarm attaches to the frame on on the same plane. The green line marks the center of the swingarm pivot, the yellow line marks the center of the rear axle.
This next diagram I overlaid the same swingarm but placed it at a 25 degree angle. This is exaggerated but it serves our purpose. Notice that the swingarm pivot (green line) is in the same place for both the zero degree example and the 25 degree example. The red line is the new center of the rear wheel axle. As you can see, the red line is closer to the green line. This illustrates how the swingarm angle can change the wheelbase. Follow?
Also, consider that if your wheelbase did NOT change as your swingarm moved, why would we need slack in our chains? =)
So, consider that there is an "optimal" wheelbase that each rider wants that gives them the right combination of handling characteristics that they are looking for. Time to throw another variable into the mix. Gear ratio.
A 16 tooth front/44 tooth rear gives you a ratio of 2.75. A 15 tooth front/41 tooth rear gives you a ratio of 2.73. Close enough that no one would notice a difference however, a 41 tooth rear is significantly smaller than a 44 tooth rear, allowing a tuner to push the rear axle out (longer wheelbase). The 44 tooth, since it is larger uses more chain length to go around it and thus requiring that the wheel be moved forward (shorter wheelbase) so not only does a racer need to determine the best gear ratio for getting around a particular track, they then need to determine which gear combination gets them to the desired wheelbase. Fun, right? :p
GYROSCOPIC EFFECT
This video should help to explain the gyroscopic effect.
https://www.youtube.com/watch?v=UiTUiop9etk
When your wheels are spinning they exert a tremendous amount of force. This force is why motorcycles just dont fall over when in motion. It also means that the faster you go, the more stable the bike becomes (wheels are rotating faster, more gyroscopic effect) with the tradeoff being that the faster you go, the harder it is to turn the bike.
Check out this video. The bike does not fall over because of the gyroscopic effect.
https://www.youtube.com/watch?v=kWfCw9hIKE8
There are other factors that contribute to how strong the gyroscopic effect is, the most notable of which is the weight of the wheel or "rotational mass". The heavier the wheel, the more gyroscopic effect, the more stable (and harder to turn) the bike becomes. Compare a relatively heavy cast aluminum wheel which is what our GSXRs come with to say, a carbon fiber wheel. The lighter wheel has a lot less mass which makes the bike less stable but easier to turn, right? Isnt less stable bad? Sure it is, which is why we would add some trail to make the bike more stable...or change ride height to give us some more rake. Are you beginning to see how everything is interconnected?
So why use lightweight wheels at all? Well, the goal is to go faster, and to get to top speed sooner and that comes down to the Moment of Inertia (MOI). This is a measurement of how much force it takes to get a wheel spinning. The less MOI, the easier it is to make the wheel spin...This is also known as faster acceleration =)
So, we obviously want to accelerate as fast as possible, so we want the wheels with the lowest MOI. We then need to adjust ride height, trail, and swingarm angles to compensate. Whee!
The actual point of this discussion...sort of
So, as was mentioned above, when you accelerate on a motorcycle, the back end of the bike rises.
Lets digest that for a moment. A lot of you right now are going "What the eff? When I am accelerating the weight transfers back and it should squat". Physics says yes. Chassis geometry says no.
When we accelerate hard and the back end of a motorcycle rises, we experience the following conditions: Weight transfers rearward. Rake decreases. Trail increases. Swingarm angle increases. Ride Height increases. Wheelbase decreases. The motorcycle becomes more stable and harder to turn. The goal is to set ALL of the above settings such that you can get the maximum stability and traction at this time. The problem in doing so is that it causes the bike to "stand up", "run wide", or "unable to finish a turn". The more gas you give, the more the bike wants to move towards the outside of the turn. Finding the delicate balance of all of this is the goal of on-the-gas suspension tuning.
When we brake/decelerate we experience the following conditions: Weight transfers forward. Rake decreases. Trail decreases. Swingarm angle increases. Wheelbase decreases. Rear ride height increases. The motorcycle becomes less stable and easier to turn. The goal is to set all of the chassis settings such that you can turn as easily as possible while having enough stability that you don't crash. This is the goal of on-the-brake suspension tuning.
So, we can't change suspension settings on the fly...so as if it weren't enough to tune on-the-gas and on-the-brake suspension, it is the tuners job to find the settings that allow you to do both of those things well. No easy task I can assure you.
Get to the point already...
And finally, the home stretch.
So we now know that the goal of every suspension is to allow the maximum ability to turn which comes at the tradeoff of becoming unstable. Can we all agree that the point which needs the most stability is at the apex/slowest point of every turn?
So here it is. A racer is coming into a corner hot, hard on the brakes. The bike is incredibly unstable as he begins to tip into the corner which he can do faster and easier because of the aggressive geometry settings he has. He trail brakes as long as he dares and then he gets on the gas before the apex because he wants to transfer that weight back to a more neutral stance and not weight the front as much. The problem is that he is still unstable from compressed geometry settings of the braking forces.
By gently dragging the rear brake...not enough to slow you down but enough to cause your geometry changes...he lessens his rear swingarm angle, lowers the center of gravity (ride height), increases his wheelbase, increases trail, and increases rake. ALL of these things make the bike much more stable.
All of that writing for the last 2 sentences =)
This technique allows an incredibly talented and very advanced rider to "cheat" chassis geometry, much in the same way that a steering damper allows us to "cheat" trail settings. He can run super-aggressive geometry that would be right at the point of crashing but right when he needs that maximum stability from the bike, he uses the above technique to give him the stability when he needs it, and the ultra-tight handling when he doesnt.
In closing: There are a TON of great books out there on chassis geometry and suspension tuning. If your inner geek/engineer is curious, send me a PM and I will see what I can find for you.
It is my hope that by having a greater understanding of what your bike is doing under you, you can become a more skillful rider, even if you don't use the technique.
Super Moderator
Nice post! Thank you!
Ey3
So a few years back I was watching world supersport and they were talking about Davies I think and said his bike is set up for braking. I understand set up for stability or set up for turning (at the basic level of understanding), but what do they mean set up for braking? The correct geometry for stopping quickest? Being able to turn while braking hard? I think he was lifting rear wheel consistently on braking.
Thanks
so yep. i used to use both brakes all the time. Was convinced around here that it was not a great idea to use a rear. Highly unnecessary. May go back to learning how to use it again in a more gentle fashion. 06 wheels no good?
I know this thread is more about the track, but on the streets I use my rear brake ALL the time...more so than my fronts sometimes. Approaching a red light, stop sign, slow speed parking lot maneuvers, and pretty much every controlled stop involves my use of the rear brake... Sometimes I dont even touch the fronts if for example I'm approaching a red light.
In a panic stop, I would probably avoid using the rear, but there's been times where I've had to stop really fast and still have used the rear without locking it. The rear brake doesn't lock up as easily as some think or claim, its just about knowing your bike and knowing where that locking threshold is.
I use it in the canyons as well if to shave off some speed before or even during cornering if i feel I'm coming in too hot.
had a couple of close calls going into corner sideways with too much rear. Backed right off it. maybe the time to introduce slowly again now i am more confident with the front.
When I started seeing all this "don't touch your rear" brake thing over the last few years I just couldn't understand why. The only thing I figure is that it's just too many controls for new riders to be able to manage effectively and they end up using "too much" rear in places where they shouldn't be. My opinion is you can use too much of any control and it's going to bite you just as bad if you do. I've been using my rear brake since about 1967 so I'm very comfortable adjusting the ratio of front and back in any braking situation. It's just automatic. And I feel I have so much more control through the corner using a touch of rear coming into corners (well, left handers anyway as mentioned). I also use the rear to help "initiate" hard braking coming off the strait. I feel it helps get the suspension planted quickly and evenly to where I can get to 100% front and 0% rear on the hardest braking on the straight. Back to a combination of front and rear when trail braking into a corner. For me the bike has always felt much more stable and it feels like it's pulling me around the corner and I have less fear of losing the front.
I use 100% of the controls given. The rear can be used as a buffer to settle the bike out in just about any situation minus mid turn and headshake situations. To set the bike up for hard braking at high speeds is my favorite use. It makes the /headfork drop less aggressive and makes me feel like my stopping/slowing distances are greatly reduced by doing so.
Discussion Starter #13
Here is the thing.
Using the rear brake on the track can cause nothing but trouble for 99% of the riders out there.
I always hear the argument that a rider can slow down faster by using the rear brake which unfortunately is incorrect.
While it does make a good suspension tool, the rear brakes ability to actually stop is poor at best.
If a rider is braking as hard as they can the rear tire should be in the air. By using the rear brake you can/will lock the rear which will cause big trouble if the rider settles the rear tire when it isnt exactly in line with the rest of the bike.
Furthermore, using the rear brake actually makes the bike less stable by diminishing the gyroscopic effect of the rear wheel which is the bulk of the bikes stability.
Nearly every rider would be better served by learning to maximize their front braking technique rather than using the rear at all.
Started riding dirt bikes in 1975 and have always used both brakes. Got a bot too hot into turn 1 at Loudon last year on a demo R6. Grabbed both brakes hard and rode a rear wheel lock up right to the tire wall. Luckily stopped before it. Former racer friend of mine said with all that load on the front slowing at speed rear will do nothing for me. This year a bit hot into a slight downhill corner I grabbed both brakes and felt the abs on my bike keep the rear settled and rolling. Same friend again said why are you using rear brake. Mentally now I focus on front only but try to use a little rear now and then to aid corner entry. That said at my limited track skill level I am on the fence and unlearning old habits is hard.
I hope to not get too off topic with this question, but to those that say its better to leave the rear brake alone, what then is the purpose of it being there in the first place? Are we talking about just avoid using it during race/track days and canyons, or just in general?
I'm genuinely interested because I've never had a problem with it.
FWIW, I use the back when I have run out of front, or know I need that little bit extra stopping power that may be available. I ride street only, rarely at 80+ % in cornering situations as that would put me so far above the posted limits that I'd end up tee boning someone pulling out of a blind driveway in my path.
If I've done it right, I've already used engine braking to some degree before I've started applying the front brake. Once I've done that enough to have the initial 'dive' from the front -- if the back is still on the ground, it's available to add a bit more braking force.
Most self taught riders tend to use the back more than they should. Your legs aren't really doing all that much, and since your legs are more powerful than your arms, it's easy to apply the rear.... since there is such a strong probability that the brakes will be applied with much more force than the front, the rear rotor is smaller, and the pad area in the caliper is less so you cannot lock it up as readily. Even with all of that, it's still relatively easy to skid the back tire.
Discussion Starter #17
Apparently there is some misunderstanding here.
This is an advanced technique, used for track riding only.
On the street, it doesnt matter which brake you use as you should be stopping using less than 10% of the actual bikes ability to slow down.
For street, I use the rear brake when I am holding myself on a hill and I want my hands free, or if I encounter dirt/gravel and need to slow down.
That is it.
As I said, in a panic situation if you are trying to stop as quickly as possible then your rear tire should be in the air, meaning your rear brake is utterly useless. If your tire is not in the air, you are not utilizing the full potential of your front brake which is the bulk of your stopping power.
ON THE TRACK this technique can help take an advanced rider to the next level. Nothing more.
Discussion Starter #18
I have gotten some PMs with a few questions that I thought might be better answered here.
First, and quickly, why my screen name is PainfullySlo :p. Speed is relative. Sure, I am faster than most but I am also slower than the fastest people. I dont want to be, so as far as I am concerned until I start to beat them regularly I am still just painfully slow. Actually, one of my earlier helmets had Kanji on it that literally translated into "slow" =)
Now on to the important questions. For starters it would be to discuss what happens when a rear tire slides. Does this mean you are crashing? But we see the MotoGP/Racer guys slide the rear (and even front!) all the time but they dont crash. Why?
There was a time, earlier in my racing when I used to describe my bike as handling "like it was on rails" as a way to say just how firm and planted the bike felt, it felt good and was very confidence inspiring. The faster guys smiled and nodded much like an adult amusing a child who just stated something ridiculous and I went on my merry way none the wiser, no doubt a few jokes were had at my expense but I was happy and my racing was progressing. The truth is that I wouldn't have been ready if they told me anything other than what I knew at the time.
The truth is that when you start to get really fast, your bike is rarely stable; it is more like riding as surf board than a motorcycle. Your bike slides around, wiggles, wobbles, and at times is downright violently trying to spit you off. That is the price of riding close to the edge.
The difference between when my bike was handling on rails and the way it is now is back then, I was adhering to the laws of physics. Now I am learning to bend them.
It is a dangerous road, and can have catastrophic results if not done properly but when used correctly, a rider can indeed cheat the laws of physics to go faster and do so quite safely...once you get past the "OH MY GOD I'M GONNA DIE" every 3-4 seconds.
Now, this is nothing new to the "fast guys". At my local track, we call them collectively "the aliens". You know the guys. Ridiculously fast, and they make it look so easy, like they were just taking a quick ride to the corner store and back. The kind that pass you on the inside of a turn when you swear you only left 6" of pavement and felt like you were going to break the sound barrier, yet they stroll on past you like you were going backwards in time.
The key is learning to control your panic response. Read that sentence over and over until you get it committed to memory. Control your panic response. Your body's natural survival instinct that will cause you to do things that your motorcycle will not like, often with bone-shattering results. When you feel your bike start to slide, your body will tell you to tense up. Grab those bars and wrestle control back! That would be very, very wrong. A rider needs to remain loose and in control at all times. Practice this, learn to force yourself to not tense up when something goes a little off, and you will find that you will have a lot more fun AND the added benefit of not crashing :p
I am going to take a step back and lay down another statement: No rider in the world, no matter how talented or skilled, can make a motorcycle perform better. Put your ego on the shelf here because no matter how amazing you (or I) think we are, we will not/cannot make that bike do anything that it is physically incapable of doing.
The simple fact is that a motorcycle in motion is the equivalent of engineering art. It knows exactly what to do to not crash. It will merrily handle just about anything that you can throw at it and come out just fine on the other side if the meat in the seat doesn't do anything too stupid to upset what it is doing.
The best riders in the world interfere the least with a motorcycles natural tendencies. Again, read that sentence over and over until you believe it, because it is truth. Rossi, Marquez, Pedrosa...they are all amazingly talented guys and it is largely because they know when to just let go and let the bike sort itself out.
That is the magic. That is the big secret of sliding the rear and not crashing. Do. Nothing.
I want to make a few comments that might seem out of place in this discussion.
Over-controlling your motorcycle is dangerous.
Over-reacting is similarly dangerous.
Your motorcycle, more times than not, attempts to correct instability by itself requiring NO INPUT WHATSOEVER from the rider.
Centrifugal force does NOT push you away from the center of a curve.
Virtually all riders know that if a bike begins to slide in a turn you should turn your front wheel in the direction of the slide. What too few riders seem to know is that *YOU* don't have to do anything and the bike will, of its own accord, turn the front wheel in the direction of a slide. Your only real job is to not inhibit that self-correcting effort by the bike.
Should you try to 'steer into the slide' and either over- or under-shoot the amount of turn required to offset the slide you place the bike into an even less stable configuration. In other words, over-controlling is dangerous.
Similarly, over-reacting to a bit of instability almost invariably makes things worse. When you ride over rain grooves and your front-end becomes squirrelly, if you put a death-grip on your handlebars you merely cause the instability of the front-end to be broadcast through your arms into the rest of the motorcycle. If your rear-end squirts briefly to the side (slides) while in a curve, corrective action on your part can turn it into a disaster just as easily as it might 'cure' the problem.
While the rear wheel continues to spin there is essentially no danger that your bike is going to fall down - gyroscopic forces are tremendously strong. Further, unless your slide is the result of hitting an oil slick or ice, you have not LOST traction, just diminished it. You are still able to accelerate (or VERY MODESTLY decelerate) while in a slide.
And though it certainly feels like centrifugal force is attempting to push you away from the center of a curve, in fact what it does is attempt to make you go in a straight line tangential to that curve.
Thus, as your slide progresses there is less and less centrifugal force at play. That means that more and more traction is becoming available to the tire. In other words, if you do NOTHING (other than allow your front-end to steer itself in the direction of the slide), the odds are overwhelming that the slide will end of its own accord.
There are three things that you could do:
Slow down - WRONG, WRONG, WRONG - this causes weight transfer to the front and will reduce what traction you have left and the bike will almost certainly end up on its side.
Nothing but allow the front-end to steer itself into the slide - works most of the time and requires no skill whatever.
Modestly accelerate - increases rear-wheel traction and shortens the slide - but requires a gentle touch (skill).
Honest! The best course of action for almost anybody is to let it slide.
Look at any motorcycle race film and you will observe that 100% of the turns are negotiated with the rear wheel sliding! Nothing magic about that, now that you know what's going on. Right?
When someone now tells me how their bike "handles on rails" I tell them that they just aren't going fast enough. Yes, it makes me sound like an egotistical prick, but I then talk to them to explain these things I am about to write down.
Discussion Starter #19
Now, guys and gals that have ridden in the dirt are laughing that I had to write all that down up above. Dirt riders steer with the back tire all the time, most of them just don't think about it because it is 'just what you do'. Traction is rarely solid on the dirt so that style of riding simply becomes sliding the rear everywhere.
The trouble comes when the rear is planted one moment, and has diminished traction the next. The trouble isn't the bike, it is the rider and coping with the sensation that we all immediately recognize as "Oh shit, I'm gonna crash" when the truth is that there is actually quite a good sized window of grey area where you are sliding but not crashing. I call it my 'slush fund of traction'. You finance people can chuckle, it's ok.
These days, I am actively seeking to break the rear tire loose coming out of a turn. By doing so, I know that I have achieved maximum potential speed. I am accelerating just as fast as I can possibly go.
But wait, why then do people crash? We have all seen (and some of us done) crashes where you lowside because the rear dropped out on you. You had traction one moment, and none the next.
Well, there are a few contributing factors that can cause this and again, we will all need to put our ego's aside because WE are the reason for crashing (barring something reducing traction suddenly like ice/oil/water on the surface).
First, I will give you a little chuckle, taken from my Middleweight SuperSport race from June of this year.
MWSS - YouTube
Why did I crash? A 'helper' in my garage neglected to turn on my rear tire warmer and it was stone cold. Race tires suck sweaty monkey nuts when cold. They are about the equivalent of riding in the rain on slicks. Needless to say, I reaffirmed my earlier decree that no one touches my bike but me so this issue will not come up again.
So, other than the times when traction is simply not there due to tire temps, water, oil, etc...the rider is the cause of nearly every other crash.
Bar input, chopping the throttle, too heavy on the throttle, leaning past the coefficient of friction point...basically doing anything other than just letting the bike do what it needs to do can and will cause a crash.
The main culprit is bar input. I see 'professional' racers make this mistake all the time, and they complain and swear about how the moon was full, or the blinker fluid was low on their bike...and I am sad for them because they will never grow as a rider until they can find the root cause and fix it. I guess it is too difficult to look in a mirror and place blame for some.
Anyway, we heave on the bars pretty hard when tossing the bike into a turn. I would be quite embarrassed if there were a microphone in my helmet when I am racing because I literally grunt and scream when I throw my weight on a bar to initiate a turn. The key is that just as quickly as you throw all that force into the bar to get your bike to lean, you have to release all that pressure and have no weight on the bars at all once you have attained your lean angle.
If you are going into a turn at close to the maximum lean angle you do not have the luxury of introducing any opposing force. The tire needs all of its grip just to keep the bike on its course. You should be completely loose on the bars at this point.
I had a guy I was teaching tell me that it wasn't possible so this was what I showed him on the next laps out.
If it werent for controlling the throttle, there would be no need to have your hands on the bars at all. Again, the bike knows what it needs to do. LET IT HAPPEN!
More to come...
PainfullySolo, that post above was very informative.
I read before that steering input/force is very crucial. And to think of the bars as handle bars, not so much a steering wheel.
Once in the turn dont put force in the bars, support your self with your outside leg and weight on the tank. Even more try and lean the bike with weight not the handlebars.
Ive only been riding since this past march (2014), however its something Im very interested in, and love learning about. I take riding very seriously. And im looking to hit a track near me next season.
1 - 20 of 41 Posts
