Greetings!
This is my first post and I am a bit frustrated, so I apologize for any typos. I just wanted to run a problem past you guys. My 06 ZZR600 was put away in the garage during winter. It was taken out a few times on milder days. For one month it wasn't used at all. In mid March I tried to take it out for a ride, but would barely crank. (it wasn't on a battery tender)
I jump-started it, rode it for a good 30 minutes, put it back in the garage. 1 week later it was too weak to crank. So, I get out the cables again, jump start it, let it idle on the drive for a good 30 minutes, take off the cables, and off I go.
I hit a nice straight away and I open up the throttle a little and when the bike hit about 9k it started jerking back and forth like I was out of gas. So I turn the petcock to reserve and on I go, ego slightly bruised.
I turn around to head home, but the bike now starts doing the same thing at 6k, then 4, then 3, finally after 20 minutes of going between 2 and 3k in 2nd gear I get home.
Battery is dead, bike won't crank. For some reason I thought the battery developed a short, so a few days go by and new battery arrives. I put it in, bike fires right up, oh joy. But I got a volt meter in the few days I was waiting and hook it up the battery.it reads 12.9 volts with the bike not running, 12.5 with bike running.
So I now figure it has to be the regulator/rectifier. I got a cheap Caltric regulator/rectifier from Amazon for like 30 bucks with shipping. It arrives in a few days, this afternoon.
I hook it up, check voltage at rest, 12.9 right on the money. I fire up the bike, and its at 13.5-14 or so, tears of joy.
I start reving it tho, and the volts start climbing. By the time I am 4k its charging at 15+ and I think I saw a 16 in there on one rev. I never approached the 9k where the original problem occurred.
So what in the blue blazes is going on? I got a manual for the ZX600G model and it specifies 14.7 +_ .5 volts whilst running, but 16 would definately be abnormal, no?
How did the bike go from too little juice to too much? Any ideas? Faulty rectifier? Bad stator?
Thanks in advance and sorry for the long post
