^YUK.......... No air filter?
yes those passageways lead deeper into the carbs---that is your main air and pilot air jets--they will tie in to the main fuel and pilot fuel passageway and essentially you could push that shit right into the idle mixture passageway and the float bowls
full disassembly and cleaning is the only way you are going to really clean this mess
Yes you can remove that pilot air jet- just don't get the jets all mixed up, the main fuel will look just like it but be a different size
take notes, read the manual so you know what you are looking for/at...
And don't spray carb cleaner all over the slide diaphragm- they swell and can be a bitch to get back together then
