1 - 11 of 11 Posts
whats up brodas :2fingerlol:
here is another DIY to help another broda do their oil and filter change :devious
so here it is brodas !!!!
YOU WILL NEED , 4 QUARTZ 10W40 OIL , A WASHER AND AN OIL FILTER AND AN OIL PAN , AND SOME OPTIONAL OIL FILTER WRENCHES TO HELP REMOVE THEM
ITS EASIER FOR ME TO HAVE MY BIKE ON STANDS, BUT ITS OPTIONAL
NOW REMOVE THE RIGHT AND LEFT BOTTOM FAIRINGS TO ACCESS YOU OIL DRAIN PLUG AND FILTER
NOW TURN YOUR BIKE ON AND GET IT TILL NORMAL TEMPERATURE, I TOOK THIS PICTURE BEFORE IT REACH IT , SO PRETTY MUCH I WOULD SAY AROUND 180 OR 190 DEGREES OR EVEN BETTER RIDE IT :)
NOW SHUT IT OFF, LOCATE YOUR OIL DRAIN PLUG AND DRAIN THE OIL INTO THE PAN
NEXT REMOVE YOUR FILTER ,I USED THE WRENCHES, AND INSTALL THE NEW ONE , PUT SOME OIL ON THE RUBBER GASKET, AND HANG TIGHTEN IT
THEN, POUR THE NEW OIL ON THE RIGHT SIDE , REMOVE THE OIL CAP, IT TAKES ABOUT 3.6 QUARTZ TO GET THE RIGHT AMOUNT, IT SHOULD BE BETWEEN THE UPPER AND LOWER SIDE ON THE OIL GLASS INDICATOR
THEN, RUN YOUR BIKE AGAIN AND DOUBLE CHECK YOUR LEVEL AND YOU ARE ALL SET BRODA, !!!!!!
THANKS A LOT !!!!
The bike needs to be standing completely straight when checking the oil level through the sight glass. Just thought Id clarify that. But good job on the info Renzo :bigthumb:
Thanks brodas thought it will help
And yes i missed that broda , thanks for the tip
Shit broda, you're lucky.
The filter on the 13's are in a really tight spot on the left side, I always end up crushing the shit out of the old filter to get it off of there, almost no filter wrenches fit. I liked my old 06's filter placement....so much more convenient.
Looking forward to more DIY broda......hoping someone will do a spark plug replacement DIY soon....it's gettin' about time for my plugs to be swapped.
Discussion Starter #9
Really broda ? Damn can you post a picture to see where the filter is located
For sure broda i need to change my spark plugs as well
Discussion Starter #11
Absolutely broda
Reactions: ZxRican
1 - 11 of 11 Posts
