My 2006 ZX6 is second hand, and since I bought it last year, I have found a bunch of stuff that was done incorrectly by the previous owner. The most common error I find while working on the bike is over tightened bolts or even stripped threads. Needless to say, its annoying and becoming all too common.
So the other day I went to pull the front brake pad pins and install a new set of Vesrah pads...the pins will not budge. Cranked on them for a bit to no avail. Pulled out the torch and heated the head of the bolt, still wont crack loose.
I stopped for the time being rather than get angry, but I am considering not even addressing this again and just buying a used set of 07+ Nissin calipers. The only issue with that is that my new pads wont work AND my current Galfer lines will be a bit long which will bother me.
Anyone have any ideas on how to get these things out? Should I order a new set of pins and just bash a removal bit into them and use that?
