hey so i just bought a 1999 ninja zx6r and when i picked it up ran fine, brought it back to my house in the back of my truck and strted her up ran it dad took it for a spin around the block she was perfect, it had been sitting for a while so the fuel was stale so he decided to put some lucas fuel stabilizer in it and then i took it for a spin got thru first gear hit second and it bogged hard!!! and then stalled got it home and it was bowing smoke and we topped it up with new fuel by the way, so we siphend that crap out went got all new fuel, filled her up, no more smoking but it will only rev to a certain RPM if you roll on the throttle, if you crack the throttle it boggs down and stalls... any ideas?
thank you
Garrett
clean the carbs. sounds like you put too much lucas in there, and the mix of that plus the old gas gummed everything up.
it's got buggers.
I read the thread title as 'begging and stealing?? please help' :laugh
oooooooook got it figured out :D pulled the tank off and i found out the crabs were justcleaned in march and all that jazz and i pulled the fuel filter out and it did not look good at all, it had little chunks and stuff in it, so went down to pro am got an new fuel filter got some motul engine cleaner and some carb cleaner brought it home put it all in put her back together and started it up .....same thing :S by then i was getting pissed off so i cracked the throttle wide open and hahaha sure enought it blew all the shit out that was in there and shes been running great since :D thanx for the help :D
