1 - 7 of 7 Posts
just put on my 2 bros. slip-on exhaust, wicked awesome! but now the fuel injection light blinks non-stop. what the dilly ya'll? how can i fix without pcIII, if at all possible? thanks peeps!
my mate at work has the same prob with the fuel injection light and its been in the shop for 5 days now and they have not a clue and waiting for a new computer to come in and sus it out.
Did it replace the exhaust valve in the midpipe?
I was thinking along those lines. But the FI light?
Samarai did you replace just the slipon?
yea, steve is on the right track, the exhaust probably didn't reconnected the butterfly valve cables that run from the module (under the front seat) to the valve on the front of the muffler. that would cause the ecm to throw a 34 or 63. you can just read the codes and find out what the computer says is wrong. just check out the file vault, then the service manual. its on page 3-41
make sure you put loc tite on the bolt that holds the bracket on, mine came off a couple times before I finally figured that trick out.
1 - 7 of 7 Posts
