1 - 14 of 14 Posts
Just put on my graves and noticed there is a lot of "after fire"/"back fire" when riding. Mostly on low rpms and when downshifting. I read a few threads about this and there seems to be no consent or a straight answer if I should worry about this?
Blockers? Retune stock computer? Get a new pc? Leave it? :O
I have a Graves slip-on on my bike and for what it's worth, when letting off the throttle it does "crackle" a bit but not really back firing. It's a pretty free flowing system but I honestly wouldn't worry too much about it.
If it's just a slip on then do the block off plates and it should kill the popping/afterfire on decal. And might as well remove ALL the smog shit at that point too. :O
If it's a full system and you haven't added a fuel management system to the mix then make that happen.
block off plates and a tune will remove most of the backfiring. i also have a graves slip on + gutted headers.
Sounds like everyone said pretty much what I was gonna say.
Keep it alive with the Graves and get their block-off plates. If the problem still persist, get a PCV or a Bazzaz and richin it up.
Consensus?
This is one of the main differences between slip-on vs. full system. Installing a full system necessitates also installing block off plates and either getting a dyno tune or ecu flash or installing a fuel controller. Without all of this your air/fuel mixture will be way off and your bike won't run right.
Basically you just opened up a money pit for yourself by installing that full system =P
Discussion Starter #12
Consensus?
Yea, thanks :)
Slip on
I love the sound it makes when it backfires, kind of miss it. But I do hear it once in a while and brings a smile...
M
Guest
Backfiring is normal without a PCV or some form of tuner but backfiring sounds cool. It's nothing bad really. It's just fuel igniting inside the exhaust on its way out.
1 - 14 of 14 Posts
