put this back up for you mike to help you out as i cant upload any pics on the original thread
there are 2 ways of fitting a b rear end on a j model
the first way is to cut and weld the rear seat frame
as you can see the j frame in black is longer and thinner than the b frame in silver
so if you go the welding route you will need to adapt the b frame (silver one) to the same width as the j frame (black one) hence cutting and welding the frame
if you cant get hold of a tig welder here is another route
adapt your j frame to fit the b plastics on
