The race fairing came in today from Armourbodies. Since there is nothing yet posted or vids about it..might as well do a small report. Haven't put them on yet but did some exploratory work first. So far investigated the seat area and the one thing that is not mentioned on their sight is that you have to cut the draft pan. This will be tough as you have to get it right so it matches up with the part. Measure 10x cut once. Have to trim by the square area where the old fender bolted to.
I weighed everything which is something that is not listed or apparently known. I called and asked and even they did not have wights listed.
upper fairing 4lbs
lower 2 lbs
seat 2 lbs
fender 1 lb
should be good weight reduction, mostly in the front. the seat area panels do not weigh much.
upper fairing 4lbs
lower 2 lbs
seat 2 lbs
fender 1 lb
