1 - 10 of 10 Posts
Any ideas on an aftermarket clutch lever for a 2019-on 6R?
I really like the feel (on the fingers and clutch pull) of the CRGs, but they only make the brake lever for the latest years.
I don't like the feel of the ASVs as much, but they do make them for the later 6Rs.
Womet-Tech Womet-Tech Evos Levers | Kawasaki ZX6R 2019+ (tstindustries.com) makes them, but I don't know how they feel.
Clutch lever feel is probably mainly dictated by the cable pull, instead of the hydraulics of the brake lever. Are you looking for an adjustable lever, or what? Just something different from OEM?
I also can't see any reason that an earlier year clutch lever wouldn't work..... same clutch, same cable, same handlebars, same perch.....
I think he means what the physical shape of the lever feels like in his hands.
OP, contact CRG and ask them if the clutch lever fits your year.
Discussion Starter · #6 ·
"I also can't see any reason that an earlier year clutch lever wouldn't work..... same clutch, same cable, same handlebars, same perch....."
[/QUOTE]
2019 - on ZX-6R Clutch Lever part # 46092-0568
Clutch Perch part # 13280-0248
2018 ZX-6R Clutch Lever part # 46092-0006
Clutch Perch part # 13280-1160
2019 and on has adjustable clutch levers.
Discussion Starter · #7 ·
I've had ASVs before, but I like the feel of the CRGs much better.
I'll try to contact CRG to see if they'll ever make the clutch lever for the 2019-on ZX-6Rs. If they won't, I'll probably give the Womet-Techs a shot.
It's a 7/8" bar, and a cable operated clutch..... very nearly the simplest control on the entire bike. You could swap out the entire assembly with ease (perch and lever), if there is something you like better.
Discussion Starter · #9 ·
Good idea. Different cables though, 2019-on is 54011-0634 and 2018 is 54011-0564, but it still might work.
I saw a perch for 2013-2018 on ebay for $17.95.
1 - 10 of 10 Posts
