what did you make the undertail out of? or did you buy it?? NEED something like that for my bike
Thanks for all the commits folks.
Arron, I made it out of some scrap card board.
J/K:devious
Actually, it was sheet metal from an old heavy duty storage shelf
I had around here.
Not too thick or heavy, just right.
Make you a good working pattern and go from there.
The hardest part was the cutting away the fender.
Not that it was that "hard" to cut.
It is just once you make a cut.... you are committed. (lil scary!)
I used a box cutter to cut through the sides.
Then used a hack saw blade (w/out the handle) and just sawed
through the rest by following the underside line of the bike, just
let it cut where it may.
Hold your card board under there to draw your pattern.....
There ya go.
Good luck.
It is really not as hard as it may look.
