1 - 3 of 3 Posts
ok i have a 98 zx6r and it wont lets me grear down unless i am accelerating.it only happens from 3rd to 2nd and 2nd to 1st.if i keep the revs up underload it will gear down.it will not work by just reving and clutch.i have tryed letting the revs go down to an idle and still nothing.think its the shifter fork? or a drum?if so will i have to split the case?will i have to replace grears?the clutch have one season on it.it wont jump out of gear.shifts up great.if anyone else has had this or heard of it happening please lets me know. Thanx
Sounds like the selector spring to me, have you tried holding down the lever then slowly letting out the clutch i have to do that with my 06 sometimes it doesnt like changing down wen your at a stop either
check your gear linkage is clean and moving freely, this is the normal reason for most gearbox problem
1 - 3 of 3 Posts
