1 - 4 of 4 Posts
Im having problem with my ZX6R at the high end speed. Sometimes i feel the bike stay when I open the throttle but it go back again. Now this is not all the times. Normally in 1, 2,3,4 gears it reapond to the throttle.
Once i pass it 5 gear the motorcycle hits 112mph to 122mph and when hit the 6 gear the top speed is not even 127mph. And is not hitting redline stay on the 10k to 14k RPM.
I already change sparkplugs, air filter is clean, and clean the gas pump filter.
What it could be, why is not hitting 157mph to 160mph as before.
Help Help Help
When were the valves adjusted last? How many miles on the bike? What's your compression like on each cylinder?
Do you have the OEM chain on the bike? What condition is it in?
Have you serviced the brakes? Do you know how old the brake fluid is?
How about the tires?
1 - 4 of 4 Posts
