2014 ZX6-R 636 ABS Build
ABS Model
Mods:
Ohlins Steering Damper
Yoshimura Frame Sliders
HID 6000k Hi/Lo Beam slim ballest
Lo-Jack Security System
Scorpio i9000 keyless Alarm system
LED Slim rear turn signals with LED relay flasher
Fender eliminator kit with LED LP light
Bridgestone S20R Dual compound tires F/R
K&N Race-Spec Air Filter
Power Commander V Ignition module
PCV Map switch control
Catalytic converter delete
Butterfly valve controller removed
Servo buddy installed
Vortex swingarm spools
M4 GP Exhaust Pipe slip-on
ECU Unleashed Re-flash
Custom Dyno tuned
Remove reflective Safety Hardware
Remove Factory Timing Retard
Remove Throttle Restrictions
Increased Idle
Increased Rev Limit
Remove Speed Limiters (Gear Dependent)
Reduce Excessive Engine Braking/Improved Deceleration
Improved Throttle Control & Reaction
Remove Injector Shut-Off on Deceleration
Improved Fuel Maps
Improved Ignition Maps
Injector Phasing Adjustment
Velocity Stack Switching Adjustment (Variable Stacks Only)
Race Fuel Mapping Accommodations
Dyno Sheets and pictures coming soon.
Discussion Starter · #2 ·
Dynojet Custom Tune
Baseline with mods; Ecu Flashed; Final
Are you sure you actually got rid of the cat? The gain numbers seem low, you should.ve gained a lot more based on the mods. Did you just remove the pre chamber or actually deleted the cat in the base of the header?
Discussion Starter · #4 ·
Edit on mods
Hey, yeah. I removed the pre-chamber, but not the Cat itself. Im trying to figure out how to edit my original post. sorry about that, new here.
